Back on the road - hopefully
Brilliant progress Garry =D>
I have to admit i'm of a similar mind with my bikes, do it yourself & get the buggers on the road \:D/
Apart from my Kr1s project, which is driving me mad. As it is turning into a nut & bolt job......grrrrrrrrr
Forks done and back in with swapped yoke
Re-built the calipers and gave them a re-spray a few coats of
lacquer and new bolts - managed to get them working without getting brake fluid everywhere :)
I think its best to just have one project at a time Howie - otherwise
you never seem to get any of them finished #-o
Hi Garry,
Looking good, I like the black wheels 8)
Nice finish on the spannies (Nikons?)
Bernie :D
Thanks Bernie
The wheels are some of the bits i have accumulated over the years
Am using some of them on this bike
The pipes are Nikons - used BBQ paint - seems to give a hard wearing
finish and cleans easy
Shouldn't be too long now before it's all back together
Rear caliper rebuilt - pistons had seized - got them to move eventually by
pushing them back, spray of WD40 and then using the brake lever - since it was having no effect on its own
Will fit the disc when the wheel comes out for a new tyre
Frame spars polished and lacquered
Got some electrics to sort out then fairing repairs
Not sure if a black mudguard might look better :-k - will wait and see when the fairings back on
dave32
Post by dave32 »
Looks good,black wheels go well with the B2 paintjob :D
How come you cut the side panels down,to get at the fuel lines on the tap easier?
ATB
Dave 8)
The reason i cut the panels Davewas because they were cracked at the front - however i think i prefer them this way - plus it does give you better
access
Have a good pair in the shed
Re: Back on the road - hopefully
Have repaired ears to the fairing and done lots of missed/botched jobs - still got a bit to
do but mainly small jobs i can do when i get a bit of spare time
