I am not going over the top with this as i want to use it
However took the swing arm out - repolished the main spars and sprayed the rest silver then lacquered the lot (rattle cans i had in the shed)
I like polished but its hard work so just leaving the footrest hangers and
end cans. I know you loose a bit of shine with lacquer but at least you
can just wash it
Going to lacquer the frame spars further down the line
Regreased the linkages and all feels tight , had a fairly new Hagon shock
on the bike and that has cleaned up like new
New seals for the forks are next and swap bottom yoke for S item
Its only cost £10.00 so far for the base gaskets
