ah it's too late for that now, but I did consider an offset. I decided to go straight through because I am a bit tight on space in that area.
THE FLUTE
Post by THE FLUTE »
This is how I did my 400 Ben
That is a nice looking solution 8)
Post by maccas »
Very Yamaha-esque! I like it!
Dan
Dymags and Brembos :mrgreen:
Cheers Phil, Mike is working on something for me.
Will you and Gary be at Snet at Easter?
THE FLUTE
Post by THE FLUTE »
Luders wrote:Cheers Phil, Mike is working on something for me.
Will be at Snett mate and Gary is there but not riding with him this year. Doing F2 british and TT with Gordon Shand. Will you be there
yep I'm not riding though, so I'll catch you on the Friday for a beer
Fuel cell made, just needs fitting to the shroud
Next steps are to get the fabrication work completed on the frame and get the rear brake hanger made.
I've been a bit quiet lately, but have been working on getting the fuel cell mounted and into the firbreglass shell and also trying to get the rear brake caliper mount sorted.
In the mean time my new master cylinder has arrived.
That looks nice Ben
(nisin radial?) 8)
500bernie wrote:That looks nice Ben
(nisin radial?) 8)
Yep 8)
Fitted a radial to my lc/rgv and it had its first ride out on Monday was a massive improvement over the standard rgv one which has a lot of lever travel.
A tip i found when bleeding, i used a Hel bango bolt (in the master cylinder) which looks better than the standard one, i could not get much pressure after a bit of time, so i took it out and looked at the difference between the two and found the standard one has a bigger bore through the middle and is abit longer than the Hel one so swapped them over and was all done in no time. :D
Here's my rear caliper hanger in the process of being turned from a chunk of billet.
like it :D
