The compression testing details are in the manual, 107 - 164 psi.
The curves exhibit the characteristic flattening in the power curve around 8K that happens when the power valve opens the sub port (KIPS). It might be only one cylinder is opening? I did have a KIPS linkage come off once in a race and there was a noticeable drop in power - pulled in as not worth carrying on.TwoStroke Institute wrote:I call it 'closing' because of closing the resonator, you could say opening the sub ports.mj43 wrote:Closing or opening? and which dyno curve.....
I meant the original curve posted.
Same thing happens with Aprilia 125's with a solenoid PV, it's the on/off, yes/no, open/close nature of this type of PV. The Aprilia is sensitive down to 100 rpm , the further you get away from optimum the bigger the dip.mj43 wrote:The curves exhibit the characteristic flattening in the power curve around 8K that happens when the power valve opens the sub port (KIPS). It might be only one cylinder is opening? I did have a KIPS linkage come off once in a race and there was a noticeable drop in power - pulled in as not worth carrying on.TwoStroke Institute wrote:I call it 'closing' because of closing the resonator, you could say opening the sub ports.mj43 wrote:Closing or opening? and which dyno curve.....
