- si.likes.guiness
Rear spindle:
Length to underside of bolt head: 330mm
Outer diameter: 20mm
Inner diameter: 14mm (apart from 45mm of 9.5mm I.D at the threaded end)
Weight: 450g
Front spindle (couldn't take it off as didn't have a stand, sorry mate)
Length to underside of bolt head (circlip in this case): 250mm
Outer diameter: 17mm
Inner diameter: 13mm (apart from 50mm of 9mm I.D at threaded end)
Haven't weighed it.
Swingarm spindle:
Total length: 300mm
O.D: 20mm
I.D: 13mm (apart from 30mm of 9mm I.D at threaded end)
Haven't weighed it.
These are from a R/RS model. The SP/SPR/ late RS models might use different spindles as the forks and swingarm are different, as are the chain adjuster blocks at the back.
Hope that's of some use
Dan
Weight: 450g
Haven't weighed it.
Swingarm spindle:
Total length: 300mm
O.D: 20mm
Haven't weighed it.
Dan
