running on 1 cilinder
Post by jarno »
I have a problem with 1 of the bikes(kr1s)
when cold it runs on 2 cilinders when warm on 1 sometimes 2 cilinders.
carbs and fueltap ultrasonic cleaned new sparkplugs and checked everything.
fuel is pooring out of rhs cilinder when driving.
what can it be,spark seems OK on bouth cilinders.
sometimes it wil pick up on 2 cilinders when driving(you can feel the extra power then)
What happens if you swap the HT leads around?
Post by jarno »
wil do that tomorrow luders.
So where I'm going with this is, if the problem switches cylinders with the HT lead swap, you narrow the problem down to the coil/plug caps etc. If it's still the same cylinder, it's more likely to be a spark plug issue or fueling related.
HTH
Re: running on 1 cilinder
jarno wrote: fuel is pooring out of rhs cilinder when driving.
shouldn't you ficks this first before looking for something else ?
Post by jarno »
i have tried to jan i think the cilinder is getting enough fuel but it wil not ignite thats way it is comming out of the cilinder next to the exhaustgasket
changed the sparkplugs for new ones
jarno wrote:i have tried to jan i think the cilinder is getting enough fuel but it wil not ignite thats way it is comming out of the cilinder next to the exhaustgasket
Sounds like the coil failing to me, I've had that before .. Running ok when cold then gradually failing to spark as it gets hot ..
jarno wrote: it is comming out of the cilinder next to the exhaustgasket
:oops:
bad reading from my part, thouht it was comming out the carbs
Post by jarno »
changed the leads and no diverence.
ik think i have found the problem.
when engine runs on idle it runs on 2 cilinders when i'm driving and asking for power it turns in to 1cilinder and smokes on the rhs exhaust
went in a drive this morning and saw alot of blue smoke coming out of rhs exhaust, so i think the drive seal is gone and it is sucking engine oil in the rhs cilinder ( when i am asking power it sucks oil in the cilinder and kills the spark)
smelled and looked at the slurry that came out of rhs cilinder and it seems to be oil.
because of the bike standing still for 13 years it makes sense
does that make any sense to you guys?
Is it using transmission oil?
This is your Zeus blue we're talking about and have you serviced it since you got it?
Post by jarno »
i think it is using gearbox oil.
the guy who i bought it from changed the oil i have changed it to.
it stood for 13 years so i think the seals dried out.
yes it is the zeus blue kr1s
sounds like your crank seals then. Try some fresh plugs, it may have just fouled them, but I think you'll be looking at a full strip down.
Post by jarno »
changed the plugs 3 times for new ones so it can't be the plugs.
its going to be a project this winter.
jarno wrote:changed the plugs 3 times for new ones so it can't be the plugs.
Still it's a Zeus blue... A jolly nice project to have =D> 8)
Post by jarno »
thats true \:D/ \:D/
maybee change the pistons to i know there still the first factory pistons.
i will place some pictures when i begin with the project.
i'm not going to to restore it its still to good for that (only cleaning and refurb).
