i am looking at getting a set of v force reeds [am building a 300cc engine for a forum member]
looking at all the posts on here, it seems that the hole in the stuffer is offset.
and it seems that the only two options are either fill and file the hole[which i am not keen on]
or buy two extra stuffers and make a pair that way.
could someone shed some light on this please, as am sure kr1r tried emailing v force
v force reeds question
- martin
Re: v force reeds question
you're spot on with those options Martin and I don't have a lot to add, other than filing is probably the easiest option.
yatasaki
file the rubber flange, there is plenty of space (rubber) to file to match the offset hole
did on two engines allready
