can anyone recomend a master cylinder to suit two 6pots
Braking issues
kxt5001987
Post by kxt5001987 »
Does anyone know the correct piston diameter to use on two front 6pots tokoyo. For use on a race bike
256 powered f2hopper sidecar
Hybrid kx500
Kxt500 mx trike
4cylinder italjet sidecar
Bultaco pursuang 360
Aprilia rs125 with 37mm carb and hrc pipe
Rotax 256 Phillips quad
Re: can anyone recomend a master cylinder to suit two 6pots
my advice : get good 4-pots instead. they are as good (if not better) in braking, weigh less (unsprung weight) and don't give as much trouble as the 6-pots (they are awfull :? ).
