Hi
Can anybody tell me if ZXR 400 H & KR-1S front wheel spindles are interchangeable.
I want to use ZXR 250 yokes, ZXR 400 H forks, KR-1S front wheel, can this be done?
Many thanks, Tony
Front Spindle
Nope the ZXR400 H model uses a bigger spindle than the KR1S. Also you'll needs spacers to move the calipers in to fit the KR1S, as the discs are closer together on the 1S.
I used a complete front end from a ZXR 400 H model which only requries the KR1S stem to be fitted into the ZXr400 H bottom yoke and then they are a straight swop.
Re: Front Spindle
As elf said they are not the same, are you specifically wanting a 1s front wheel, to match the rear?Steely wrote:Hi
Many thanks, Tony
If you can get zxr250 yokes, spindle, speedo drive, front wheel etc then you could have a one off spindle made which would allow you to use zxr400 forks and calipers (or 1s calipers which are the same as h1 zxr400 L series are different) The zxr250 front wheel is different to a 1s, it certainly has a different code on it and when I was messing about a 1s wheel did not fit with the the zxr250 spacers.
Of course anything is possible, depends on what time, money and machining facilities you've got, me I've got none after going for the set up outlined above.
- Steely
Front Spindle
Hi
Thanks for the quick replies.
I looked at the team sparrow website, and it says there that a guy in japan swapped in a ZXR 250 front end using a KR-1S front wheel, it says it is tight, but it fits.
Finding ZXR 250 bits is not easy, if i could find some i may give this idea a go.
- Steely
Front Spindle
Hi Red Devil
Okay had a look at your thread, looks like a good way to go, only problem is going to be getting a new spindle made.
Can you give me some idea what i need to do, get it machined.
Many thanks, Tony
Many thanks, Tony
