Evening all, first post looking for some forum wisdom....
I have just bought a KR1S and as a precaution took the top end off for inspection and put in new wossner pistons and bearings.
When dismantling the head from the barrels it took alot of strength to 'break out' the head bolts (I wanted to inspect power valve condition - one was sticking).
I put the head back on the barrels with new head gasket (identical to previous gasket) and found that I could only tighten the head bolts finger - tight before the powervalves started binding up and getting hard to rotate. I tightened the bolts up a little bit more and fired the bike up with some sort of hope that a bit of heat would help things settle back in.......however coolant was pretty much running out between the head and cylinder (gasket).
Totally puzzled. I tightened the head even more to try and stem the coolant leakage but obviously the powervalves are now solid and wont budge!
Does anyone know whats going on? I bought the gasket set with the pistons from PJ i think it was. They are installed with the 'UP' side upward. Aside from that I cant figure how to get the head on tight enough without binding up the powervalves???
If anyone can figure out a workaround for this I will be really really happy.
Many thanks,
Dave
