crankshaft B2 C3
Mouser
crankshaft B2 C3
Post by Mouser »
Hi,
Does the crankshaft from a B2(1989) fit to an C3(1991)? Is it exactly the same part?
Thanks
Mouser
Re: crankshaft B2 C3
Post by jarno »
yes it is the same.
James P
Post by James P »
I'm not disagreeing with Jarno, but the part numbers are different:
B1, B2, C1, early C2 crankshaft complete 13031-1287
B1, B2, C1, early C2 LH ball bearing 92045-1215
late C2, C3 crankshaft complete 13031-1326
late C2, C3 LH ball bearing 92045-1247
Since the ball bearing is included with a complete crankshaft, the different ball bearing may explain the different crankshaft part number. Anyone know if this is true?
If the ball bearing is the only difference, what is the difference between the two ball bearings??
Thanks & regards,
James, different part numbers don't mean parts aren't interchangeable.
there is no difference, sizes off all the parts are the same. maybe they switched from bearing manufacturer, I don't know. KR1 and KR1S had different piston's, still they are interchangeable.
James P
Post by James P »
JanBros wrote:James, different part numbers don't mean parts aren't interchangeable.
Yes Jan - I agree that they are interchangeable - I just wondered if anyone knew the differences between the bearings and/or crankshafts 8)
