Oil Advice
Oil Advice
I am thinking of moving from Motul 800 to Motul 710,
Does anyone use 710 at the moment?
Also, should I be able to wait until the tank is nearly empty and just add the 710 or will I need to drain and flush?
Re: Oil Advice
Bernie , the key thing here is engine speed and forward motion. As you have niether , then bite the bulet and select the best2T to suit your bike.
Re: Oil Advice
Strictly speaking Bernie, the motul 800 factory line oil is for pre mix race engines.
I would run what you have down low and stick in the 710. Slightly mixing the two types won't make a difference.
Re: Oil Advice
Thanks guys,
I am hoping the 710 will burn better at lower temps, avoiding oiling up
Re: Oil Advice
Post by SHimmer45 »
a good quality fully synth is the way to go, i used to use Sil and Rock oil without problem
slashing
Re: Oil Advice
Post by slashing »
I use the rock fully synthetic also the castrol power one when i can get it for the right price i find the rock burns the cleanest out of the two an the price is better on the rock if you purchase it in 4 litre container.The premix oil is thicker than injector stuff i would say the flow rate through the pump would be slower due to the thickness i would stick to the injector lube if it was me.
