42 teeth sprocket
Mouser
42 teeth sprocket
Post by Mouser »
Hi,
Anyone tried a 42 teeth sprocket on the Kr1-S yet?
Where can I get a 42 teeth sprocket for the KR1-S? Really didn't find any on the whole web..
Thanks
Mouser
Re: 42 teeth sprocket
thinck I've got 39 to 45 sprockets. bought twice parts from ex-racers :D
I can have a look see what I have left
Mouser
Post by Mouser »
headcoats wrote:http://www.bandcexpress.co.uk/shop/tran ... ockets.htm
These will make it for you :wink:
:cry: No 42teeth sprocket, only 41...
dirk
Post by dirk »
Hi Mouser, Hi there
http://www.intobikes.co.uk/products/001 ... 250C3-1992
but why do you need 42?
regards
Mouser
Post by Mouser »
Hi Dirk!
Many thanks for the link dude :)!
Searched about 3-4 h on the net yet, found at least 15 sites but non with 42 teeht :)
Why 42? Wanted to give it a try :)..
Do you think it's to much ?
cheers
Mouser
its easier to alter the front up or down
equivalent to +- 3 on the back
to see if its the result youre after
http://www.jtsprockets.com/catalogue/model/5230
you should NOT run a 14/42 combination due to uneven wear and cyclic issues
evenly divisible means the same tooth will see the same chain links every revolution
if you have ever ridden beside someone with a poorly maintained chain at speed youll understand the problem
