42 teeth sprocket
Posted: Sun May 04, 2014 10:14 pm
by Mouser
Hi,
Anyone tried a 42 teeth sprocket on the Kr1-S yet?
Where can I get a 42 teeth sprocket for the KR1-S? Really didn't find any on the whole web..
Mouser
Re: 42 teeth sprocket
Posted: Sun May 04, 2014 10:19 pm
by headcoats
Posted: Mon May 05, 2014 6:44 am
thinck I've got 39 to 45 sprockets. bought twice parts from ex-racers
Posted: Mon May 05, 2014 7:04 am
I can have a look see what I have left
Posted: Mon May 05, 2014 11:47 am
by Mouser
No 42teeth sprocket, only 41...
Posted: Mon May 05, 2014 1:06 pm
by dirk
Hi Mouser, Hi there
http://www.intobikes.co.uk/products/001 ... 250C3-1992
but why do you need 42?
regards
Posted: Fri May 09, 2014 10:03 pm
by Mouser
Hi Dirk!
Many thanks for the link dude
Searched about 3-4 h on the net yet, found at least 15 sites but non with 42 teeht
Why 42? Wanted to give it a try
Do you think it's to much ?
cheers
Mouser
Posted: Sat May 10, 2014 12:04 am
by KR-1R
its easier to alter the front up or down
equivalent to +- 3 on the back
to see if its the result youre after
http://www.jtsprockets.com/catalogue/model/5230
you should NOT run a 14/42 combination due to uneven wear and cyclic issues
evenly divisible means the same tooth will see the same chain links every revolution
if you have ever ridden beside someone with a poorly maintained chain at speed youll understand the problem
