hello all ,how do you strip powder coat off wheels.
thanks
wheel stripping
bsa70
Re: wheel stripping
With great difficulty. I just stripped a couple of rear footpeg hanger brackets, using Nitromors and it took ages (I left them in a bag filled with the stuff for a week, and it was still really difficult) ended up using 120 grit and sanding it off.bsa70 wrote:hello all ,how do you strip powder coat off wheels.
thanks
What are you going to do with the wheels once you have them stripped?
bsa70
Re: wheel stripping
hello sounds hard getting it off ,was going to get them re coated in lime green.
cheers bsa 70
cheers bsa 70
Re: wheel stripping
That's easy then......bsa70 wrote:hello sounds hard getting it off ,was going to get them re coated in lime green.
cheers bsa 70
They always blast them before they coat them, just make sure all your bearing surfaces are protected.
Re: wheel stripping
and your threads. I always put some not good looking bolts in them ( make sure they stick out enough)
Re: wheel stripping
Good adviceJanBros wrote:and your threads. I always put some not good looking bolts in them ( make sure they stick out enough)
