Hi all,
Does anyone know where I can get a complete list of parts needed for a Crank and Top end rebuild and also where to source the parts from?
I know this might sound like a silly question as anything could be wrong with the motor and you only really know when it's opened up. What I'm looking for is the most common parts used in a complete refurb.
Shep
Engine Overhaul
Re: Engine Overhaul
Have you looked through the manual?
Re: Engine Overhaul
complete crank rebuild, new piston's, if needed new nicasil and maybe correcting head if it's damaged. oh end new oil seals for the KIPS valves.
only way to be sure if you do not know it's history.
piston's can be found almost everywhere, crank parts BDK or PJME ?
