Need help!
Bike wont start!!
Pretty sure everything is fine . . . . .
Got spark and fuel in carbs
Tried quick start still no luck
Were these difficult starting bikes
Rebuilding my first of two KR250 Tandem Twin Bikes
- lurker
Re: Rebuilding my first of two KR250 Tandem Twin Bikes
I am also about to begin rebuilding one of my many KRs.
Apparently the dampers in the primary gears can cause hard starting if they are out of spec?
It is covered in the clutch section of the workshop manual.
Others here will probably be able to shed more light.
Hope this helps.
Good luck.
Hope this helps.
Good luck.
- Top-shaggy
Scroll down page re dampers and starting..
Also see full workshop manual on Tims site
http://kr250.org/KR_service.htm
I also think the starting problem is contributed by the kick start not turning the engine fast enough, try bump starting when hot works on mine starts easely
1984 Kawasaki KR250A
2 Smokey and they bandit
