good Morning all
can i use replacement piston rings (RIK) for genuine piston?
regrds
genuine piston -> replacement piston rings ??
dirk
Re: genuine piston -> replacement piston rings ??
the genuine rings are diverend than the rik rings Dirk.
cheers Jarno,
cheers Jarno,
dirk
Hi Jarno
thank`s for the answer.
Are any other pistons rings than the NLA for the genuine Pistons available?
cheers
cheers
never heard of other rings for the original pistons.
are you looking for them?
Jarno
Jarno
Re: genuine piston rings ??
13008-1146 rings C2
still available in Japan ¥3810 approx £23 each
http://www.kawasaki-motors.com/for_user ... g/Estimate
- James P
I haven't yet confirmed it 100%, but I strongly suspect that RGV250 genuine rings will work with the KR-1S piston. Both are 56mm bore, the rings being 1.2mm thick, with ends which close over the ring peg.
I made some measurements from a (supposedly) VJ22 bottom end with pistons still attached and they appeared to be the same as KR-1S. I think the Suzuki part number for the VJ22 standard rings is 12140-22D30.
The VJ21 models used rings with a different part number, so I can't comment on whether they would be any more or less suitable.
As far as I know, the RGVs used a keystone section for the top ring and a plain rectangular section for the bottom ring. I can't be sure that this will match every version of the KR-1S piston - perhaps someone more knowledgeable could advise?
