changing forks
changing forks
if you change forks to zxr 400 ,what else do you have to change. many thanks jason
Re: changing forks
Your wheel usually
Re: changing forks
stem if you go for L-forks
Re: changing forks
The H has smaller diameter lower yoke by about 1mm I think. You can use the standard ZXR stem if you make up a spacer as the stem is slightly longer (it just means your top yoke will sit a bit higher).
Re: changing forks
if you do a little search on the forum, you'll find tons of info
