KR1-S Best aftermarket pipes
shandyboy
Post by shandyboy »
Looking to leave my new acquired bike standard other than a set of aftermarket exhausts anyone know whats the best set too run with ???
cheers
Alan
Re: KR1-S Best aftermarket pipes
Just get some custom ones made, there are too many negatives with off the shelf pipes.
shandyboy
Post by shandyboy »
Whoes the best to use Iam In Newcastle?? Also bike is out the packet as new 1500 miles on it one owner from new, not sure if I trust someone messing with it !!
someone suggested Jim Lomas ???
cheers
Alan :)
You'll lose peak power unless you raise your exhaust ports and even worse, you will need to chop your belly pan around becuase they are too fat!
Wow .. Did I read it right .. 1500 miles from new?
If it's in great origional condition I would leave it alone .. The stock S pipes are pretty good as they are and unless your mad keen on saving weight .. New pipes are not worth the cost / hassle. I would leave stock and enjoy :)
Shaun makes a very good point, leave the stock pipes on.
How about some photos?
shandyboy
Post by shandyboy »
point taken will get sum pics posted at the weekend
thanks
Alan
shandyboy
Post by shandyboy »
What about just changing end cans mainly for looks !! any problems with running issues was thinking tyga ones ????
Changing exhausts doesn't make as big a difference as people think or believe, unless they are custom.
Changing your end cans will be a purely cosmetic move.
Fitting JL pipes people think you need to change your jetting. In reality, unless you raise you exhaust ports, you'll lose top end hp over standard pipes.
I have spent a while looking at the exhausts on the KR-1S and can genuinely say, I can make at least 5bhp over standard with the design Lozza and I came up with.
Two people on here know this from their own dyno experience.
mj43
Post by mj43 »
From my testing and experience the best aftermarket pipes are either Lomas or Jolly Moto. I have also tested 3 or 4 other makes but all lost power relative to stock KR-1S and gave no significant benefit elsewhere in the rev range to compensate.
On standard barrels both Lomas and the Jolly Moto will give a significant boost to midrange from memory of the order of 5hp. They both appear to knock off 2hp at the top end. For Road use and occasional trackday I would say they are a good choice. The Jolly Moto are a better fit then the Lomas so (again from memory) avoid the belly pan issue. With the Lomas pipes to avoid the belly pan melting you will need to create a heat shield.
I have yet to see any pipe significantly improve on stock KR-1S pipes at the top end.
The thing to do would be for me to bring my pipes to try on Andy's bike, with your motor Mark and do a back to back run
mj43
Post by mj43 »
I think Andy was planning on going on the dyno on Wed?
My bike won't be back by then
proddyraceKR1S
Post by proddyraceKR1S »
Any one any figures on Nikon pipes got a set with my bike never fitted them left standards on it would be nice to know if nikons any better???
