Early KR1 CARBS FLOODING
waza1972
Post by waza1972 »
Hi all, just restoring an F reg KR1 and when the engine stops the left carb leaks from the over flow tube by the exhaust. I took the carb apart and cleaned all the jets and the float valve as they were gummed up because it had been say for years. Put it back together and its now running but when revved its taking a while for the revs to come back to tick over and when you knock it off its still leaking out of the over flow about a minute later. Any help would be great, Cheers Waza.
Re: Early KR1 CARBS FLOODING
You need to fully strip the carb, take off the holder secured with the security screws (as it will be full of crap).
Make sure you check/set the float hights before you put them back together.
waza1972
Post by waza1972 »
Xlent, cheers. Any tips on how to check float hights (never done it). I have just ordered a new float valve aswell.
waza1972
Post by waza1972 »
Xlent, cheers mate. Any tips on how to check the float hight?
and place inline fuel filters :idea:
waza1972
Post by waza1972 »
Any tips on setting float hight, never done it.
