Hope someone here can point me in the right direction.
I've got an S engine with one S and one KR1 barrel. Both need replating. Is there any chance of finding a second hand L/H barrel or should I buy some KR1 barrels and have them plated? I have the S exhausts, carbs and CDI, guess I should run all that stuff?
Do I need to run smaller mains with the KR1 barrels?
What is the difference in the KIPS valves, I looked at all four and they look identical? Could it be that they are all S and they do fit but are a different profile?
Sorry for all the questions, if this was a YPVS forum (sorry for the bad language) I would be ok but these green things are new to me...
Thanks
Advice needed
buzinc
Re: Advice needed
Hi. You need both barrels to be the same. ie kr1 or S. The S i would guess is more plentiful, someone on the forum should be able to help supply.
The kip valves again on the S have a bigger hole - usually have 1132 stamped on the shaft.
Both types of valves will fit in both types of barrel - but I wouldn't swop about, the S has a tad more power so get the S barrel and S valves.
Check with manual on the forum for jet sizes
Buz
Buz
smoovly
Re: Advice needed
Thanks, will check what valves I have but they all look the same so I suspect are S ones.
Just waiting now for someone to sell me a spare barrel.
Re: Advice needed
I think B cylinders are more common. C cylinders are more in demand and in theory rarer, as many are/were raced.
