Unfortunately, it seems that Mitaka is now advising against fitting the expander supplied with its new-style KR-1 piston kit. I am wondering why an expander is supplied at all if it is detrimental to the operation of the piston and/or rings.
I haven't got any of these new-style Mitaka piston kits for the KR-1, so I can only make measurements of pistons which I have got (those which are supplied with expanders).
Anyway; I took some measurements from the following pistons:
KR-1 (Mitaka old-style, 1KT-based piston, marked 01-2010, with Riken rings)
KR-1 (Mitaka intermediate-style piston, actually branded "Aoki" on the box, perhaps the first of the Taiwanese production, with Riken rings)
TZR/TDR/R1-Z (OEM ART piston with Teikoku rings)
TZR/TDR/R1-Z (Pro-X branded aftermarket piston with Riken rings)
TZR/TDR/R1-Z ("SA" branded aftermarket piston with Riken rings)
SDR200 (OEM ART piston with Teikoku rings)
IT175 (Pro-X branded aftermarket piston with Riken rings)
Instead of taking up loads of space with measurements, I'll make a few statements of my findings. All measurements have been rounded-off to the nearest 0.1mm:
The thickness of the expander in every case (whether Riken or Teikoku) was 0.3mm.
Generally, the "horizontal depths" of the upper and lower ring grooves were the same.
The widths of the upper rings were about 0.3mm less than the horizontal depths of their associated grooves (i.e. after the piston ring becomes flush with the skirt of the piston, it can be pushed a further 0.3mm into the groove).
In most cases, the width of the lower ring was 0.3mm less than the width of the upper ring (i.e. adding together the thickness of the expander and the width of the lower ring gave the same result as the width of the upper ring).
There were two notable exceptions to the above; On the old-style Mitaka KR-1 piston and the "SA" branded TZR piston, the lower ring groove was an additional 0.2mm "deeper", meaning that the expander would be compressed less. I wonder if that lessens the chance of the expander breaking...
Could someone who does own one of the new-style Mitaka KR-1 pistons make some measurements to see whether this piston and its rings conforms to any of the general patterns mentioned above? With such measurements, it MAY be possible to decide whether the new-style Mitaka KR-1 piston has had its grooves incorrectly machined, or whether incorrect lower rings have been supplied, or whether there is some other reason that the expanders have broken (material too brittle possibly).
Thanks & regards,
