CRANK LEFT HAND BEARING REMOVAL ISSUE, Magneto side
bsa70
Hi i have a bearing puller extractor,but i cant get it behind bearing, to pull it off, as it is so close to crank web,any ideas how to achieve removal ,advice appreciated thanks.
Re: CRANK LEFT HAND BEARING REMOVAL ISSUE, Magneto side
never done it myself, but you'll need a hydraulic press and a home-made jig (or something like that)
bsa70
i just cut through outer ring in 2 places ,tapped it and it fell off,bearings in cage pulled off, the puller gripped the inner ring and pulled it off.as i was replacing them,
