Throttle grip
Throttle grip
Any one know what other models use the same throttle grip? As it has a sort of cover for the sticky out bit on the throttle tube, being technical here "sticky out thing"
1984 Kawasaki KR250A
2 Smokey and they bandit
Re: Throttle grip
Googled the part-number (46019-1056) : PartZilla says it's used on the 1984/5 GPZ900R.
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
Yamaha RD350LC,
Re: Throttle grip
well it seems the right hand one is discontinued, no one has it, so two left ones ordered from Cradley Kawasaki, they were the cheapest, going to have to remove the sticky out bits, lol. can not see they serve any purpose.
Re: Throttle grip
[quote="dougindoors"]well it seems the right hand one is discontinued, no one has it, so two left ones ordered from Cradley Kawasaki, they were the cheapest, going to have to remove the sticky out bits, lol. can not see they serve any purpose.[/quote
lugs removed a good blast with the air line and on they went.
