The best for pitch and offset is ZXR250A Triples , the pin is too short for a direct bolt on though.
For simplicity a complete 250A front end recommended and do a pin swap from KR yolk to ZXR yolk , clip on bars need to be swapped over too.
Hate is goes from 4 pot to trailing 2 pot but my next mock up is brackets to hang 40mm 4 pot Brembos , I suspect the mounting lugs on the ZXR forks will need to meet an angle grinder though but hopefully 7075 that thin on the mounting will be strong enough
Overall very pleased with the look , nothing looks too out of place and retains a factory fitted feel about it.
