Coolant leak that I can't stop
R1andy
Post by R1andy »
Hi,
I replaced the engine casing section that houses the clutch cable and cannot stop a coolant leak. It's coming from a small hole right beside the coolant drain bolt.
It's a minor leak but still a leak.
Has any one had this issues and how did you fix it?
Re: Coolant leak that I can't stop
Post by jarno »
I think your waterpump seal is gone
jarno wrote:I think your waterpump seal is gone
X2 :(
Gerrit
Post by Gerrit »
Agreed. Remove the primary drive cover after draining the cooling system and strip the water pump, thoroughly inspect the ceramic ring in the impeller and the carbon ring in the stationary part of the seal. There's probably either a crack in the ceramic ring or the carbon ring is damaged, more likely the latter, meaning the seal assembly will have to be replaced.
R1andy
Post by R1andy »
Thank you for the advise folks, side of the engine off again this weekend lol
Ah the joys!
Dragongoal
Post by Dragongoal »
