Runs ok-ish but not happy up to 5000rpm, from there to 6000rpm it's an absolute pig! .... not backfiring but close, hicking and objecting, you would think it had a loose HT lead or running half choke on a warm engine. Once it hits 6000rpm it's fine and revs happily, if I hold it on part throttle in the 5 to 6000rpm band it feels like it's running out of petrol. On the open road you can avoid all this but when you hit traffic it's bloody dangerous.
THINGS I'VE TRIED:
Cleaned carbs, ( no change )
Fit new plugs, (problem has improved but still not right)old plugs were perfect colour when removed.
Swapped the CDI for a known good one ( no change )
If I have to take the petrol tank off once more I'm going to launch it down the drive.
