32mm carbs
col
32mm carbs
Post by col »
will rgv 32mm carbs work on a kr1?
obviously gonna have to find rubbers but if i can will they work or do the rgv jobbies non starters?
I have a set, just tried to see if there is enough room and that is ok.
can't see why they shouldn't work. might take some time to set them up properly.
col
Post by col »
i wasnt sure about all the extra nonsence they put on the rgv carbs, you know the air acutator stuff, whatever that does, i've no idea
sprocket stu
carbs
Post by sprocket stu »
my brother in law has just fitted a pair to a rd400 with good reults, as for the actuator set up all he did was blank off the extra pipes to prevent leaks.we are yet to have the bike out in anger but results in the garage are good up to now
col
Post by col »
apparently yhe earleir models didnt have the actuator :?
mj43
Post by mj43 »
They are a bugger to set up. Colin Sleigh had a set working.
My advice is unless you can get the settings of Colin stick to PWKs they are a lot easier to work with.
Bikemike
Post by Bikemike »
I've just spotted these on ebay,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %26fvi%3D1
Could this be the same Colin that Mark mentioned?
If so you've got half a chance of getting them working.
Mike
yes it is the same one - i bought quite a few bits off him in the past
doesn't seem to be registered on the new site yet - not sure if he knows
about it - have sent him a message
