Reed petals
- gangus
Reed petals
what does everyone use these days?
Need to use oem reedblock for production racing so Vforce are out.
are they still available from kawasaki?
Thanks in advance
Thanks in advance
- James P
Re: Reed petals
The part number 12022-1057 is shown discontinued. Can you use Boyesen petals? If so, I think Boyesen numbers 607 and/or 639 will fit the standard reed block. Boyesen also makes a less expensive "Superstock" single-stage reed which will also fit - SSF or SSC 014 I think...?
Re: Reed petals
NLA from Kawasaki.gangus wrote:what does everyone use these days?
Thanks in advance
Are yours knackered?
- gangus
Re: Reed petals
cheers James, will look into them!
corner missing on one i'm afraid Bernie, otherwise tension and seal looked good on the other petals.
Gerrit
Re: Reed petals
I think KX125 reed petals may fit, but not sure of this.
Re: Reed petals
I think I have a spare set in the loft, I will have a look later to see if they are ok.gangus wrote:cheers James, will look into them!
Rocket
Re: Reed petals
hy-tech do some,
part no's;
HT81
or
CF81 (carbon fibre)
part no's;
HT81
or
CF81 (carbon fibre)
TwoStroke Institute
Re: Reed petals
Throw VF2's in from a KDX 200 or better still Boyensen RAD valves. If you want to use the standard cage (really good OEM cage/stuffer BTW) you can buy Polini or Malossi blank petal material and cut your own reeds. Blank material is available from scooter shopsgangus wrote:what does everyone use these days?
Thanks in advance
crochet & croquet
Re: Reed petals
any suggestions on matreial and thickness TSI ?
TwoStroke Institute
Re: Reed petals
0.32-0.35 seems to be the sweet spot JanJanBros wrote:any suggestions on matreial and thickness TSI ?
crochet & croquet
- gangus
Re: Reed petals
Stock measure 0.37-8mm for reference
Re: Reed petals
doesn't it depend on the material ? glassfiber vs carbon vs metal vs ...?TwoStroke Institute wrote:0.32-0.35 seems to be the sweet spot JanJanBros wrote:any suggestions on matreial and thickness TSI ?
- gangus
Re: Reed petals
It would depend on material, but I'm certain we are all talking cf
