Hi folks
I need to change the KR1S forks seals and oil change.
In the manuals are different capacity:
KR-1: 421ml +-4ml when assembling
KR-1S: 360ml +-4ml when assembling
i thought both bike has the same fork?
regards
dirk
different forks on Kr-1 Kr-1S?
Re: different forks on Kr-1 Kr-1S?
Hi Dirk,
schöne Grüße,
no they're different. KR1 got 37mm forks and KR1S 41mm.dirk wrote: i thought both bike has the same fork?
schöne Grüße,
wrong CharlesCharles wrote:Hi Dirk,
schöne Grüße,
so why is the capacity different ? don't now, but probably 'cause it leads to a different set-up.
- Garry
ouch, sorry for thatJanBros wrote:wrong Charles![]()
I read that somewhere ...........
may explain the kr1's overdamped forks, the 1s was probably revamped to try and calm things down a bit but still a bit choppy on a bad road, i have wrists that agree im right! on a track however the std forks with there old oil are akin to a motocross bike in terms of been sloppy! maxton do a good job of rectifying the problem apparantly, hope to find out at some point over winter.
