kr1s swinging arm pivot bolt
bsa
Post by bsa »
any one know what other kawasaki uses same bolt,
the kr1s is thicker than kr1 bolt
bsa
An RGV swing arm bolt is a straight swap for the KR1S and is a hollow bolt as well, so it's a big weight saving mod :lol:.
mgtkr1
Post by mgtkr1 »
any one know the kr1s pivot bold od off hand? my kr1 has a kr1s swing arm but i suspect iot has had work done to the swingarm rather than frame? the previous owner mentioned summat about machining to enable the kr1s swinger to fit but cant remember exactly what weas said. i can work out whats what if i know the pivot bolt sizes of the kr1 and kr1s. thanks guys, is there much in it between the rgv and kr pivot bolt? fancy that, an rgv part been used to SAVE weight on a kr!!!!!
Red Devil 777
Post by Red Devil 777 »
17mm for a 1s, 15mm for a 1, I think. I've seen a 1 frame that had had it's pivot holes opened out for a 1s swinger and Col had a bush made that allowed you to fit a 1s swinger into a 1 frame using a 1 bolt-I think :lol:
bsa
rgv swing arm bolt
Post by bsa »
the-elf wrote:An RGV swing arm bolt is a straight swap for the KR1S and is a hollow bolt as well, so it's a big weight saving mod :lol:.
hi what cc is the rgv,as i dont know anything about this bike thanks
bsa
mgtkr1 wrote: thanks guys, is there much in it between the rgv and kr pivot bolt? fancy that, an rgv part been used to SAVE weight on a kr!!!!!
Yep and its the onlypart on an RGV that's lighter than the KR one :D
Re: rgv swing arm bolt
bsa
Its a suzuki RGV 250 VJ22 model swing arm bolt.
bsa
Post by bsa »
bsa
cheers elf very handy, bsa
Post by maccas »
just a quick note, the kr1s swingarm pivot bolt is 20mm od and the kr1 is 15mm od
micricco
swingarm bolt
Post by micricco »
so is it definitely 20mm kr1s and 15mm for the kr1,need to make sure before i start what i am up to :shock:
Post by maccas »
yep 100% i had to drill my kr1 frame out to 20mm for the kr1s swingarm and pivot bolt to fit, or you could make a sleeve to fit in the kr1s arm and use the 15mm kr1 spindle bolt
micricco
pivot bolt
Post by micricco »
much appreciated,just wanted to know before drilling,needed to know just in case the swingarm i wish to fit,i could fit 1s one instead many thanks
