After having a load of grieve from idiot lights I got another idiot light set and wires. This one is the best of the 3 I have and the connectors are tight and hold bulbs firm. All the bulbs are tested and working... but now the oil and neutral light wont come on (bulbs are good) They did work before but now they dont. The high beam and indicator work. They stopped working on the old set of idiot lights and I though it was just because I messed up the connectors trying to get them to hold the bulbs in tight. Any idea why the oil and neutral lights would stop working ? I changed the fuses also incase it was that but no luck. I am fairly sure its not the idiot light and its wires to the black connector as they are in really good order so its somewhere else.
Any ideas appreciated before I smash it with a hammer
wiring diagram is a bit vague but it looks like it goes through the diode pack...get a multi meter out and check for infinite resistance one way...no resistance the other...if you get resistance both ways the diode pack is fcuked....best of luck
danny harris.....R.I.P
gone but totally forgotten...
always listen to mr b,repeat always listen to mr b,repeat 20 times!you know he knows!had a same ish problem myself on one today,what i found was the connector didnt fit tight enough that goes on the bottom of engine so just flattened it a bit with pliers for a snug fit and bobs ya,sorted.bet its what mr b says though
steady on...if the wiring diagram was a bit more in depth i may b able to trace the wires from the oil light to a common connector..maybe the cdi but its a crap diagram...give me a day ill try to induce it tomorrow...
Thanks for the help. I think it was me messing around with the old idiot lights and their crap connections on the oil and neutral bulbs which has blown something somewhere. Will check that diode. The bulbs were constantly flickering and falling out of the sockets.. now ive got a good idiot light set with good connections the oil and neutral dont work at all.. have to laff I guess heh.
Tested the diode there (using the manual description) with a multimter and it reads nothing one way and a fair bit the other which is what its meant to do it seems from manual. Should it read a little bit one way ? mine seems to register nothing at all one way ?
