help please! cylinder head confusion
dirk
Post by dirk »
hi folks,
my english is bad, but i try to explain because i am helpless with this fu... head.
ok short story
head was warped.
My machinist has skim the head around 0,5mm.
After this there was no edge round the combustion chamber an the squish was to less (~0,6mm).
i am told him that the squish band must recessed into the head by 0.4mm and angled at 15 degrees.
I thought a squish clearance around 1mm is safe.
today he has finished the work.
ok at home i measure the diameter from the combustion chamber (edge to edge).
The diameter is exactly 56mm. :shock:
the piston has 55,6mm.
my old destroyed head has an combustion camber diameter from ~57,5mm !!
ok my questions.
why is the diameter from the standard head combustion chamber much bigger then the cylinder bore diameter?
can i use the head with 56mm?
the head skim was 0,5mm.
to much compression now?
ok i know... many questions and perhaps some stupid questions.
I have a new crank, new coated cylinders and new pistons.
i have no interest to destroy the engine with a bad cylinder head....
[-o<
thanks
dirk
kr1s... what an bike.
i think sometimes i sell this bike. :-k
Post by scooble »
From my understanding, the combustion area of the head should have a diameter that is the same as the cylinder i.e. 56mm.
If you took 0.5mm from a standard head, your squish would PROBABLY be Ok, however, you need to measure this. Its quite easy, poke a piece of solder wire in to the cylinder via the spark plug hole and trap it between the piston and the head by gently turning the engine over with the kickstarter by hand. Remove the squashed solder wire and measure with a set of vernier calipers. 0.8mm is about right and as Elf said, anything below this is getting a bit close. Do this for the front, back and left and right of each cylinder. Reducing the squish only has only a moderate effect on the compression ratio and does not require higher octane fule. I did this for mine and it was fine - so you 'should' be Ok.
Scooble is correct but do all four positions together to compensate for piston rock. your squish should be about 0.8mm. The reason why the old cylinder head was different diameter was probably down to crap maching tolerences.
The angle of the squish band should be a bit more than a tangent from the domn of the piston, this is to push the unburnt fuel back into the centre of the chamber.
dirk
Post by dirk »
hi
thanks for your help.
the squish clearance and bore diameter should be now ok.
it is ~0,9mm.
next big problem...
the head leak again after few seconds.
left and right hand.
i have tried two times.
first with an used genuine head gasket and a little bit "DIRKO HT" (silicone sealer).
do not work -> leak
second a new not genuine head gasket -> leak
here is a picture from the "new" head.
is it possible that the surface is to rough??
with the fingernails i can feel the grooves
dirk
dirk wrote:here is a picture from the "new" head.
dirk
I'd say yes :-k
I would also agree that its too rough. sand it down with a sheet of wet and dry stuck to a piece of glass or another suitable and flat surface.
I had a head machined ages ago and had simular problems, turned out that the head wasn't held down correctly while being machined and had flexed. I had to then polish the head flat again.
kwackman12
Post by kwackman12 »
Dirk as far as i'm aware you shoulde'nt use silicone sealer on head gaskets, You should use a sealent like "Blue Hylomar" or perhaps someone else can sugest something different
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
dirk
Post by dirk »
hi
ok
I'll try it with a sheet of wet and dry and "Hylomar".
but "Dirko HT" is here the best friend for any leakage.
here a picture with more distance,
sure looks it not so bad as the first picture, but you can see the groves.
dirk
Post by dirk »
is it possible, after the head is machined, that the pins (guide sleeves) are too long?
dirk wrote:is it possible, after the head is machined, that the pins (guide sleeves) are too long?
Unless there is some thing in the holes stopping the dowels seating then no. For the cost you could always get some new one's, from memory they only cost a few pence each.
dirk
Post by dirk »
Hi
a friend of me inspected the head again.
the head was not flat (0,08mm) and the surface a little bit too rough.
:evil:
however
machined again (0.1mm) and now the head is flat with a clean surface.
barrels detached.
torque down the head with new dry genuine gasket in many tours.
than torque down the barrels.
Squish clearance now 0.9mm
run the bike 130km and no leak!
torque down the head and barrels again.
That's that! \:D/ \:D/
Post by scooble »
glad to hear that you got it all sorted, it feels good when it all comes together. Its the little things like that which make a good reliable engine.
