if you undo all the bolts in the S front calipers do they come apart so
you can overhaul them/remove pistons?
Caliper Cleaning
- Garry
Caliper Cleaning
Red Devil 777
Yes, they'll split, but it's easier to pump the pistons out than to remove them after (unless you've got a piston remover).
Don't lose the small o rings that seal the two caliper halves together unless you're replacing them.
Dunno if they're any use to you, but I've about 6 caliper halves that I'm going to bin, save you the job of splitting them
- Garry
Red Devil 777
