Other Calipers
Braking issues
Other Calipers
Post by alimorg »
Are there any other calipers that fit the KR-1? I know there is other stuff that fits the S but have not heard anything about the 1
Al
Post by alimorg »
Further to the above, have a look at these:
Nissin 4 pots on a ZZR 600
Tokico 6 pots on a ZZR 1100
Does the ZZR family have the same calipers as a KR-1S? if so a few handy brake upgrades there.
Anyone found any info on the KR-1?
Al
rgvsean
Post by rgvsean »
If you mean a straight bolt across look at bike from the same era. Some may only need spacers to line up to the disc.
alimorg wrote:Does the ZZR family have the same calipers as a KR-1S?
yes :wink:
and those 6-pistons on the 1100 are from a GSX-R 1000 K1 I think, and are a straught swap.
THE FLUTE
Post by THE FLUTE »
yes :wink:
That,s correct mate also the K2 but nothing later
col
Post by col »
is it me or do the 6 pots look to big for the discs?
it looks as if the rear pisin id at a greater diameter than the disc.
col wrote:is it me or do the 6 pots look to big for the discs?
that will be you Col.
some thing to do with age ..... :twisted:
DavyB16
Post by DavyB16 »
do these fit the kr-1s as well, or what does exactly?(even with adapter plates etc)
i have the same 4 pot cbr-rr calipers fitted to my rvf, so my original rvf calipers cud go on the kr...
Kawasaki KR-1S C3
h***a RVF400 RR
http://DavyB16.bebo.com
mj43
Post by mj43 »
The brakes as fitted if working like new are awesome.
Putting 6 potters on, whilst looking bling, only adds unsprung weight. You would also prob need to fit wider discs as the KR-1 runs very light very narrow disks. Both these may improve braking marginally but if the brakes are tip top they are already capable of putting you over the handle bars.
Thogh the SP version of the ZXR400 runs KR-1S type calipers I have fitted boring old ZXR400L calipers (downgrade?) as they are 1/2 kg lighter.
Fitting 6potters + the bigger discs may increase your unsprung mass 2kg :shock:
If going bling go upside downers with radial calipers then I think you win all round performance + looks.
WEll thats my tuppence
rgvsean
Post by rgvsean »
MJ, not sure of KR brakes but ont he RGV the 6 potters weighed the same as the 4 pot anchors. I am going over to Brembo when funds allow. I am sure there will be a fitment that can be adapted to a KR too.
