Post
by headcoats »
i have a new chain rubber/slipper to put on the swingarm but i want to drill say a 5mm hole top to bottom to attach it
Question is,is it o.k. to drill the box section
Post
by Garry »
sure there is a good reason - but why can't you attach it via the normal method?
Post
by headcoats »
I should have explained
As my swinger is on an RD and with it jacked up,the chain is touching the swinger more so i have a KX 250 chain rubber which is a bit longer.
Post
by the-elf »
I've drilled and tapped them in the past to fit a shark fin chain guard without problems.
