KR1S front wheel tightening
Just looked on the info for this and it need to be 65 lbs but noticed that
where the speedo drive is held in by the 2 little bumps,i had to push the fork in slightly so it pressed against this before i tightened the fork bottom pinch bolts.
Is this right or is there sequence you have to do ?
