Transmission Oil Inspection Window
Ian_B
Post by Ian_B »
Hi,
Can anyone tell me how the transmission oil inspection window is secured within the clutch release cover? I've got a new clutch release cover and need to fit an inspection window into it.
Thanks,
Ian
dirk
Post by dirk »
hi Ian
the window is only press-fitted from outside.
you can it carefully remove from inside to outside.
i think it is better to buy a new one.
it cost only ~10 Euro or ~ 9 pounds.
Gauge,Oil Level
OEM#: 52005-0019
Ian_B
Post by Ian_B »
Thanks for the information Dirk, I'll buy a new window as you suggest.
Ian
