never heard that before................go standard.....
leaking valves seems to be a problem - a lot of people seem to have
cured it with new ones - i just fixed it by adjusting as the needle itself didn't look worn - not sure if it has affected the overall volume of fuel in the float bowl - haven't had the throttle fully open long enough to find out
yet
Kawasaki built a good little bike in the KR. Put it together as they intended and it will be ok. Muck about with float heights and you will have problems.
Secret to a reliable build is being meticulous and clean. When I have stuck to that never had a problem - problems only occur when I get sloppy and lazy.
When you do any work on it it should be so clean you could eat your breakfast off it.
i stripped the carbs loads of times mark - it actually became quite
enjoyable in a warped way
i ran filters and all seemed clear inside so was at a loss apart from
adjusting the floats as a last resort - will see about reducing the
height until i find the leaking point
thing is i'm reluctant to start tinkering again while it seems ok
