barrel platers recommendations please
i can supply plain ,de studded ,blasted ,de greased barrels
Re: barrel platers recommendations please
There are only really two Fred
I will chat with both. See if they do a bulk discount.
mellorp
I used TTW for ceramic plating. He gets a good trade discount, as he sends in batches, and then passes this saving on to customers. It's cheaper using TTW than going direct.
https://poetonaptec.co.uk/
http://www.thetuningworks.co.uk/store/p ... cts_id=708
I have heard that too
Thanks. That info is good to know
DougB
I've had a set done by Langcourts and a set Aptec coated. The finish on the Aptec barrels was definitely better. The Langcourts barrels were perfectly useable but had pits in several places, they came back with a note stating that it was normal and I didn't worry about it, but the Aptec cylinders looked perfect out the box.
