another forking convertion LOL
kinkyfreestyler
Post by kinkyfreestyler »
Hi could some one please tell me the full extended length of a kr1 fork ,top to centre of the axle , thanks .
I have done a swop for a set of zxr 400 l forks and can't remember the length of the originals ! its so I can get a base setting for how much I need to slip through the top yoke.
Also what amount do you have popping out the top yoke ? I know what the manual says , but most of you will have strayed from that , so what do YOU run ?
thanks guys
s**t happens get over it
Gerrit
Re: another forking convertion LOL
Post by Gerrit »
722 mm, coincidentally (or not so coincidentally) the same as Suzuki RGV250 vj22 fork legs.
kinkyfreestyler
thanks for that , can any one tell me how much you run thriugh the top yoke .
DougB
Post by DougB »
The manual says 10mm from top of yolk to top of the fork tube.
Coose
Post by Coose »
I have ZXR400L forks in my KR1 running an RGV swinging arm and 17" back wheel and I've pulled them through the yokes by 10mm to get it to hold a line, but may yet go a little further...
I'll go measure mine in a bit
Mine is set at 8mm if that helps
kinkyfreestyler
8mm thats intreasting mine are set at 10mm but the forks are a little longer than standerd so thought you would have gone the other way ?
what did you do to the internals ? springs etc ?
thanks for the replies , by the way
Ah this is a good point and has reminded me why.
I have an R6 rear shock in this bike which raised the rear slightly, even with a 17" VJ22 rear wheel. I must have measured it all at the time (2012) and came up with 8mm for the geometry I desired. Sorry if it's not very helpful.
kinkyfreestyler
most helpfull thanks , what did you do about the front springs ?
I left them as they were, as they didn't seem overly stiff for my racing needs.
Hi Ben is that the ZXR400SP forks or the TZ ones?
I'm talking ZXR in this case, not SP though.
TZ looks totally different...
Coose
Post by Coose »
ZXR are Showa, v-twin TZ are Kayaba though look similar externally. On my old TZ I could have the bike stood there with leaky fork seals and within less than an hour it would be back in one piece without leaky seals. With the ZXR forks it's a very different matter, and unfortunately it's a job that now needs doing....
I had almost forgotten how nice the bike looks. 😎
