Page 1 of 2
another forking convertion LOL
Posted: Wed Jun 05, 2019 12:55 am
by kinkyfreestyler
Hi could some one please tell me the full extended length of a kr1 fork ,top to centre of the axle , thanks .
I have done a swop for a set of zxr 400 l forks and can't remember the length of the originals ! its so I can get a base setting for how much I need to slip through the top yoke.
Also what amount do you have popping out the top yoke ? I know what the manual says , but most of you will have strayed from that , so what do YOU run ?
thanks guys
Re: another forking convertion LOL
Posted: Wed Jun 05, 2019 9:32 am
by Gerrit
722 mm, coincidentally (or not so coincidentally) the same as Suzuki RGV250 vj22 fork legs.
Posted: Thu Jun 06, 2019 8:53 pm
by kinkyfreestyler
thanks for that , can any one tell me how much you run thriugh the top yoke .
Posted: Sat Jun 08, 2019 10:10 am
by DougB
The manual says 10mm from top of yolk to top of the fork tube.
Posted: Thu Jun 13, 2019 11:04 pm
by Coose
I have ZXR400L forks in my KR1 running an RGV swinging arm and 17" back wheel and I've pulled them through the yokes by 10mm to get it to hold a line, but may yet go a little further...
Posted: Fri Jun 14, 2019 1:58 pm
I'll go measure mine in a bit
Posted: Fri Jun 14, 2019 2:39 pm
Mine is set at 8mm if that helps
Posted: Mon Jun 17, 2019 1:01 pm
by kinkyfreestyler
8mm thats intreasting mine are set at 10mm but the forks are a little longer than standerd so thought you would have gone the other way ?
what did you do to the internals ? springs etc ?
thanks for the replies , by the way
Posted: Mon Jun 17, 2019 3:17 pm
Ah this is a good point and has reminded me why.
I have an R6 rear shock in this bike which raised the rear slightly, even with a 17" VJ22 rear wheel. I must have measured it all at the time (2012) and came up with 8mm for the geometry I desired. Sorry if it's not very helpful.
Posted: Sat Jun 29, 2019 11:13 pm
by kinkyfreestyler
most helpfull thanks , what did you do about the front springs ?
Posted: Sun Jun 30, 2019 9:18 pm
I left them as they were, as they didn't seem overly stiff for my racing needs.
Posted: Sun Jun 30, 2019 10:00 pm
Hi Ben is that the ZXR400SP forks or the TZ ones?
Posted: Mon Jul 01, 2019 11:36 am
I'm talking ZXR in this case, not SP though.
TZ looks totally different...
Posted: Mon Jul 01, 2019 4:33 pm
by Coose
ZXR are Showa, v-twin TZ are Kayaba though look similar externally. On my old TZ I could have the bike stood there with leaky fork seals and within less than an hour it would be back in one piece without leaky seals. With the ZXR forks it's a very different matter, and unfortunately it's a job that now needs doing....
Posted: Mon Jul 01, 2019 9:02 pm
I had almost forgotten how nice the bike looks.
