Hi all, Paul from North Wales, decided to introduce myself after lurking for a little while, this forum seems to be an excellent source of information so thought it’d be good to subscribe too.
I’ve recently purchased a KR1, well actually several buckets of bits and a partly assembled frame, so currently rebuilding as much as possible to see what’s needed/missing/ defunct.
Hopefully you knowledgeable lots will be able to help me out with my queries.
PS my first time owning a KR1, previous had KR1S, TZR’s.
Hi! New member with a project KR1
Paul250B
- Binetta Steve
Re: Hi! New member with a project KR1
Hi Paul you are in the right place for quality information. Use the search facility to look at previous owners rebuilds. It will save you hours of head scratching.
Welcome to the forum Paul.
You will find all the information and help you need here.
Paul250B
Thank you Steve and Bernie!
Yeah I’ve been lurking for a few weeks and I’ve read up on a couple of the restorations.
Some really inspiring work going on!
I’m starting to compile a list of parts needed, majority of it is fasteners, most of which I’ve sourced, must admit the temptation to go stainless was almost irresistible.... almost.
So far I know I’m a couple of brackets short, rear of tank fixing bracket, I seem to remember from the KR1S it’s like a threaded tube welded to a plate? A small strengthening bracket on the rear seat mount (easy enough to copy) and looking at the parts manual I’m a little unsure of the rad mounts, I have a bracket for the top, looks like 2x m6 into frame, and 2x m6 through some dampers into rad, what is there at the bottom and where does it fix too? Some photos would be good so I can see the bracket.
Coose
Hi Paul, and welcome.
As above, the search function on this forum is excellent, where you'll generally find the answer to any KR-related question you have!
This forum is quite rare in that every participant is decent, helpful, and is extremely enthusiastic. Some have even been on the telly too!
