Oy
Gonzo355
Oy
Post by Gonzo355 »
Is there any reason apart from porting/matching with the same top end and cdi ,
that it would be slower.
Flywheel e.g
Gonzo355
Re: Oy
Post by Gonzo355 »
I mean I’ve swapped the bottom end btw
Gerrit
Re: Oy
Post by Gerrit »
Worn crank seals?
Re: Oy
Clutch lever adjustment
Gear box oil level too high or wrong oil
Clutch plates worn or weaker Springs
Gonzo355
Re: Oy
Post by Gonzo355 »
Defo crank seals as half the oil is in the zorsts
