balance shaft
kinkyfreestyler
balance shaft
Post by kinkyfreestyler »
Hi , I am just rebuilding my kr1 engine and the book says there are punch marks on the crank and balancer shaft but I can't find any ?
So I have set the crank at tdc and the balancer at 180 away from tdc ie. piston up weight furthest away from piston using a mark on the weight level to the casing
is this correct ? looks logical but could any one confirm it for me .
thanks
s**t happens get over it
Re: balance shaft
i find it hard to believe there would be no punch-marks on the gears of the crank and the balancer shaft.
I certainly wouldn't trust what you've done.
kinkyfreestyler
Re: balance shaft
theres no punch marks . i spent a goo while looking an nothing
kinkyfreestyler
Re: balance shaft
Hi everyone ,
Just a little up date on my problem. Well finally started the bike and it runs smooth as !
So you can set it the way I discribed , just in case some one else has no punch mark.
yes I know everyone is shouting there should be punch marks , but there isn't so I made an educated guess and it works :P
Keep riding people and if anyone is near the devils bridge this coming sunday about 11AM we can treat everyone to a smoke and noise show :P
