DP Anglesey 30/31 May
mj43
Weather forecast is good - if you get a chance come along to watch. 400 class is red hot this year. Tweo strokes go well at Anglesey - not sure mine will cracked another barrel at Cadwell and am running a bits and pieces machine just hope it holds together.
Pity I can't make it with work etc. I'm sure you can get the barrel weld repaired if its cracked in the normal place. Perhaps you can get the strength increased by buttering up the cylinder with weld metal and then remachineing?
mj43
