Thought i would post on here about this one.I am after some spacers to fit a R6 shock to my track bike.Thing is,i have never had owt like this made up before,so i am after a bit of advice.
This is what i am after
Two spacers needed,as the fzr shock is 10mm wider than the R6.It uses a 12mm bolt as opposed to a 10mm.
The green section needs to be 5mm wide,diameter doesn't really matter,anywhere between 14-20mm.The red section should be just under 12mm diameter and 7mm long.
Where would the best place to get some from,or better still,can anyone on here make them?
