Hi folks
has anyone experience with the spar parts for the crank from pj motorcycle?
especially with the con rod kit?
http://www.pjme.co.uk/acatalog/Kawasaki ... m_End.html
thanks
cheers
engine parts from pj motorcycle. quality?
Thanks for your answers.
i use the con rod kit made by "Long" since ~3000km in my TZR.
i don't know the company.
the big end bearing is different to the original Yamaha.
the bearing has a needle less.
perhaps not good for high RPM?
and now my TZR sounds not good.....
http://www.divweb.com/rd/videos/tzrbadsound.html
(it is not so loud in reality)
in hope not the crank...
perhaps only loose power valves.
Shit..... i am a old man and have forget to check the flyweel.
But here is a new soundfile
http://www.divweb.com/rd/videos/polrad.html
can you feel some movement in the flywheel ? I guess not, than you would have posted "Tnx Jan"
Does it make the sound
* anywhere -by that I mean any cranck angle - ?
* only when you change the rotation direction or even when when you just keep rotating ?
* only at BDP off one off the cylinders ?
