I am planning on fitting 30mm carbs to my KR-1S, but rather than modding my original stuffers, i was wondering if i could use stuffers from a KDX 200, these are 35mm if i am correct.
Don't want to go down the 35mm carb route, just after a small power increase.
Thanks in advance,
Tony
30mm carbs & KDX 200 stuffers
- Steely
Just wondering what "30mm" carbs do you plan to use?
I got a pair of "30mm" OKO (Keihin copies) a while back, only to find that they are pretty crap quality, and not even a true 30mm carb. Turns out they're just a cheap 28mm clone that have been machined out slightly so that the thoat measures 30mm high but only 28mm wide, leaving it somewhat egg shaped.
If this is what someone is trying to sell you (there's heaps one ebay) I'd recomend you dont touch them. If you want a slightly larger carb youd be better off getting your old carbs machined out, although I hear that those who've done this in the past weren't exactly impressed with the results.
- Steely
